Results 1 to 3 of 3
  1. #1
    Join Date
    Dec 2018
    Location
    Miami, FL
    Posts
    24
    Default Livewell Parts, Installation, and Recommendations/Questions
    Hey Johnson/Evinrude Outboard Forum,
    The reason for this post is to ask the community to point me in the right direction when it comes to choosing the right Livewell products and tools for my boat. I currently own a 1997 Stratos 2100 Center Console 21 Ft offshore boat and attached to this post is an image of my vessel. I believe the compartment just forward of my center console would be an ideal spot for a livewell but there is no pre-existing livewell installed. Since I am currently deployed and away from my boat, I do not have the measurements of the compartment but my intentions are to use my boat to go off-shore fishing in Texas and Florida. With that being said;
    1. What products/parts do i need when it comes to installing a complete livewell system?
    2. Is there an exact flow rate/gallons per hour that is specific to keep my bait alive and well when off-shore fishing?
    3. Do i need to run cables through the hull of my boat to my battery and switch on my dash?
    4. Would installing a small screen on the PVC pipe that sucks out the water be a good idea to help the livewell filter last for a longer period of time?
    A diagram with specific instructions or a step-by-step video would be of great help. Hope to hear from you guys soon!
    ​​​​​​​-Shesho
  2. #2
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    1,075
    Default Re: Livewell Parts, Installation, and Recommendations/Questions
    Quote Originally Posted by Shesho View Post
    I'm really suprized there isn't a livewell on that boat. I thought typically center console boats had a seat in front of the console that doubles as a livewell. Guess I was wrong on that one.
    Parts needed:
    1) Thru-hull 500 GPH livewell pump
    2) Stainless Mesh intake screen
    3) About 25' of 3/4" bilge pump hose
    4) Livewell sprayer nozzle
    5) Quantity of two, 1 1/8" thru-hull fittings to use as a drain (one on the livewell, one on the side of the boat)
    6) About 10' of 1 1/8" tubing for the drain.
    Cables?
    Yes. I would suggest a 2nd, deep cycle battery to operate the livewell. Put an automatic timer on it like this one so you can just set it and forget it: https://www.amazon.com/Leisure-Lectr...BDMQ133F5CN2SJ
    This timer will allow it to run continuously so you can fill the livewell, then turn it to a timer setting for automatic on/off cycles.
    Wire the 2nd battery ground directly to the pump and the timer. Then, run the battery positive directly to the timer, then from the timer + to the pump.
  3. #3
    Join Date
    Dec 2018
    Location
    Miami, FL
    Posts
    24
    Kevinj,
    You sir are a boss! I was wondering the same thing and apparently the guys at my local boat repair shop told me these boats (Stratos) don't typically have a built in live well. They also told me it would be quite difficult to install one but I'm assuming that they don't care to do it. I appreciate the time and thought of pointing me into the right direction.
    -Shesho
Similar Threads
  1. Replies: 4
    Last Post: 12-30-2018, 06:35 PM
  2. Livewell Parts, Installation, Recommendations/Questions
    By Shesho in forum Johnson Evinrude Outboard Forum
    Last Post: 12-29-2018, 12:25 PM
  3. More Questions!? Parts this time!(sorry!)
    By Jack Blant in forum Mercury Mariner Outboard Forum
    Last Post: 02-23-2014, 07:19 PM
  4. LIVEWELL PROBLEMS
    By carlnap in forum Mercruiser Sterndrive Archive
    Last Post: 05-17-2007, 01:14 PM
  5. OMC stringer parts interchange questions
    By mike alwine in forum OMC Sterndrive and Inboard Archive
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
