Results 1 to 5 of 5
    Default Getting this “project boat” soon...
    Found it on Craigslist:
    https://sierravista.craigslist.org/b...768811632.html
    Its cheap. It’s thrashed. But... it floats! I’m not planning on keeping/repairing the engine, as I’m going with an electric conversion. However, I’m wondering if I’m going to need to repair that fiberglass subfloor or not. I’ll take better pics once I have the boat, but hoping I can get some guidance before then.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,579
    Default Re: Getting this “project boat” soon...
    Ayuh,..... My guess is, yer gonna be replacin' the stringers, transom, 'n deck,.....
    Quote Originally Posted by bondo View Post
    How/where do I test to see what/if I need to replace? I’ll be removing the engine/sterndrive, to thoroughly clean everything, so I’ll have full access at that time.
    Dec 2006
    5,579
    Ayuh,..... Test borin's,.... Drill a small hole in suspect wood structures, 'n inspect the drillin's,.....
    If ya find dark/ black wood, it's rotten,......
    If ya find still good yellow/ beige colored wood, reseal the holes with resins,....
    Boats rot from the bottom, up,.... so test down low,.....
    Nov 2005
    Mt. Zion, Illinois,
    847
    You’ll also want to inspect the flotation foam in the floor. When that gets saturated you add a bunch of weight to the boat. If you’re diverting tinejectric that means you’ll be adding several batteries. You want to minimize weight as much as possible so ditching the water logged foam will be important.
  1. New Project boat 26 Bertrum hard top
    By MAMako21 in forum General Boat Repair Topics
    Last Post: 11-05-2017, 02:13 PM
  2. First time boat project
    By regi375 in forum General Boat Repair Topics
    Last Post: 10-25-2017, 10:02 AM
  3. Project boat, no spark bad to worse
    By dcooper in forum Mercruiser Sterndrive Forum
    Last Post: 09-07-2013, 12:10 AM
  4. Project Boat 1983 270
    By MrGadget in forum Volvo Penta Gas Engine Forum
    Last Post: 05-09-2010, 09:55 PM
  5. BOAT ENGINE PROJECT
    By cbdinak in forum Volvo Penta Gas Archive
    Last Post: 08-05-2007, 03:07 PM
