Click for Volvo Penta parts and manuals!
Results 1 to 6 of 6
  1. #1
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    10,404
    Default Pinging Janne kad42twin.... re; DP-D helmet removal
    Quote Originally Posted by kad42twin
    i am trying to remove my steering helmet
    i have used the technike with wooden kil
    Stop screw is removed
    i have also heaten up the steering arm inside
    it is not coming out
    do you have any tips for how to proceed?
    janne - stockholm
    Janne, I could use a bit of clarity........... what is technike and what is wooden kil?
    And when you say "it is not coming out"...... what is not coming out?
    If you are trying to remove the helmet pin (as to further remove the entire helmet), you should see two (2) jack screw threaded holes adjacent to the two main helmet pin fastener holes.
    These will be 1/4" NC threads.
    If that is not your question, please post here.
    Rick
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  2. #2
    Default Re: Pinging Janne kad42twin.... re; DP-D helmet removal
    It is the part 17 i am trying to force downwards with wood wedges (kil i call it by mistake)
    http://www.marinepartseurope.com/PentaPictures500/18696.jpg
  3. #3
    Quote Originally Posted by kad42twin View Post
    i am trying to do the job in point 22 in this document:
    https://f01.justanswer.com/ref/http_...om/JL0ySb0.jpg
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    10,404
    SEQ # 17 is the "collar steering fork".
    You will be using wooden wedges in this area as to protect the paint finish.
    Have you loosened the spindle arm?
    Portland, Oregon
  5. #5
    I have loosened the hex stop bolt and also removed the pin connecting to steering piston
    this is totalky stuck
    any ideas how to get this loos?
  6. #6
    Ok
    now its losened
    eeded lots of heat on the arm part
    thank you
Similar Threads
  1. helmet steering pin removal procedure
    By quint in forum Volvo Penta Gas Engine Forum
    Last Post: 03-17-2013, 01:05 AM
  2. Pinging noise under fly wheel
    By wish2fish in forum Johnson Evinrude Outboard Archive
    Last Post: 07-23-2009, 02:14 PM
  3. 2002 SeaDoo Utopia 185 pinging sound
    By rotor in forum Miscellaneous marine engine topics
    Last Post: 03-13-2009, 08:38 PM
  4. PINGING
    By redvett in forum Volvo Penta Gas Archive
    Last Post: 06-22-2008, 05:10 PM
  5. Pinging
    By buddy072 in forum Mercruiser Sterndrive Archive
    Last Post: 03-12-2008, 11:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
