Fishhawk-----Sorry , but crankcase compression and cylinder compression are totally different.------Crankcase compression does not have anywhere near 60 PSI !!!
The Yamaha system is much better than the Vro system. In the top 2 all time great oil injection systems. Suzuki being the other one.Right okay, that makes sense, there isn't enough residual oil for off season. So owners should fog before storage. That way bearings get protection too. Adding oil just to cylinders, would not help the bearings much, or were storage problems limited to cylinders, rings and pistons? For many years, I limited my repairs to smaller size motors because I had a shop at my home right in town and rarely worked on bigger boats and hence VRO's. So many that I repair now have been tampered with and/or disconnected. I like the variable ratio idea and the system is so much more precise than the early oil injections based on throttle position only......like my 1969 Yamaha DTI enduro.
How did the OMCs not.So how do the smaller Yamaha motors that run at 100:1 deal with long periods of storage ??
I believe the original poster has not been on here since the 8th.-----So I believe he has the motor running like new now.
