I know winterizing is a very talked about topic but after a lot of research I still haven't found an answer to my question. I have been a boat tech for awhile but just recently started winterizing boats for the last few months and the one problem I continue to run into is draining the blocks, on most boats I can drain both blocks without a problem but every now and then (mostly gibson house boats) I can only get to one side of the block (theres not enough room to get to the other side)
Need more info! Are these V engines or in-line engines?
I have heard that you can drain just one side of the block and it drains all the water out of that side and MOST of the water out of the other side (the side you can't get to)
For a V engine, this is not true.
For an in-line engine, I believe that in most cases you would see a drain port on one side only.
and then from there you can run 4 gallons of antifreeze through the sea strainer and you will be fine, are there any experienced techs out there that can confirm this or that has another solution?
I understand you can run the engine up to temp to get the thermostat to open or even take the thermostat out but its not realistic for me to do that when I am responsible to winterize up to 100 boats a year, would greatly appreciate answers.
Please read my write-up from 2012, and read it twice if need be.
https://www.amazon.com/gp/customer-reviews/R3BD7X6QC3KCFR?ref=pf_vv_at_pdctrvw_srp
If you plan to provide winterizing services, it may behoove you to carry an O&E policy!
It would also be a good idea to have the owners sign a form stating that they understand their engine has been winterized, and that any engine operation will negate the winterized state of protection.
And for what its worth since we are on the topic of winterizing............
(copy/paste from one of my other posts)
Fogging a carbureted engine is a dynamic process (running engine) whereby the fogging solution is to be introduced equally into each intake manifold plane (V engines). By using both primary throttle bores, the solution enters each plane.
(for a V-8 engine, if we miss one intake manifold plane, we will have missed 4 cylinders!)
It is best when a helper holds the throttle at about 1,100 RPM as you spray the fogging oil equally into both primary throttle bores (or both throttle bores of a 2 brl carburetor).
The helper will hold 1,100 RPM as you begin to spray the solution into each primary throttle bores.
The helper will then cut the ignition (still holding the throttle position) as you continue to spray until the crankshaft comes to rest!
The ignition is cut as to prevent combustion of the fogging oil!
This is true engine fogging, and can take place within 10 seconds or so!
Keep in mind that we DO NOT fog MPI system engines! That requires a different process, of which is not actually fogging!
