df300
An after thought, if you meant the water pressure relief valve, remove the lower starboard cowl and look at the front upper part of the mid section and you will see an oval plate held on with two bolts, that is the water pressure relief valve.
[thanks I did mean the water pressure relief
QUOTE=iang6766;627137]An after thought, if you meant the water pressure relief valve, remove the lower starboard cowl and look at the front upper part of the mid section and you will see an oval plate held on with two bolts, that is the water pressure relief valve.[/QUOTE]
