Hello anyone. I did an engine swap in my 1978 Skiff Craft, with alpha one out drive. I was sure pretty sure on my hook ups and connections. I've got everything back together and working, but my tilt is reversed on the buttons... down is up, up is down, and when when i use both up and trim it binds. I've re-done the connections several ways,still the same result. I thought the 90 degree angle line went to the pump, and the 45 degree angle connection went to upper mounting plate gear assembly (it is the other way around?) Also, I have leak at the gear assembly that I can't figure out where it coming from. Unfortunately I'm too stupid to figure out how to upload pics to this forum, otherwise I would to make it easier for someone to catch my error.
Anyway, thanks in advance,
Greg A
Greg A
