Click for Perkins manuals!
Results 1 to 15 of 15
  1. #1
    Axel Nagel's Avatar
    Axel Nagel Guest
    Default " Hi. I just bought a older bo
    " Hi. I just bought a older boat with a Perkins 4 cylinder fresh water cooled diesel engine installed.
    It is supposed to be a 4.108 55hp from 1982, but I am not sure now.
    Found the engine number on the engine block just where the injection pump is mounted.
    The number is: 7112958.
    Can anyone give as much info as possible (Type/hp/year) on the engine I have?
    Thanks in advance. "
  2. #2
    Join Date
    Jun 2000
    Location
    Forest Dale, VT, USA
    Posts
    1,681
    Default " Axel, Perkins engine numb
    " Axel,
    Perkins engine numbers should be a combination of up to fifteen letters and figures. Your number doesn't seem to fit their Engine ID sysytem.
    Regards,
    Andrew "
    Andrew Menkart
    MarineEngine.com
    "There is no situation in which knowledge is more truly power than at sea."
    - Lord Brassey
  3. #3
    roy abrams's Avatar
    roy abrams Guest
    Default hi perkins made one engine wh
    hi perkins made one engine which i own one without the 4 108 or 4 107 sufix no on it
    4 means 4 cyl 107 means 107 cubic inches
    6 354 is therefor six cyl 354 cubic inches
    and so it goes
    but 107s have smaller head studs 3/8 inch
    108s are slightly bigger 7/16
    if yours are 7/16 with 4 separate cold start plugs in the head its a 108 inch but later model
    no plugs in the head then????
  4. #4
    johnhamilton's Avatar
    johnhamilton Guest
    Default "My Perkins 4.108 has become d
    "My Perkins 4.108 has become difficult to start, & when it does finally start it is running unevenly, struggles to build up revs & surges back & forth mildly. I have ruled out a fuel problem, new filters have been fitted etc. there seems to be more blue smoke exiting the exhaust. I fear the rings may be shot....has anyone got any ideas? John Hamilton."
  5. #5
    kelly foyle's Avatar
    kelly foyle Guest
    Default hi can anyone help? i have a p
    hi can anyone help? i have a perkins 4107 in my boat it is approx 35yrs old the diesel injection pump has broke can anyone point me in the right direction on getting another one. A few people have told me i have no chance as spares are not made anymore for the 4107.
  6. #6
    Camping Classic's Avatar
    Camping Classic Guest
    Default "Early Perkins engines used en
    "Early Perkins engines used engine numbers as you discripbe. Numbers starting wiht 73 is 4.108, and 71 is 4.107 engine.
    See workshop manual at http://www.capedory.org/manuals/Perk...shopManual.pdf
    According to this manual from 1983 the current engine number system is 15 letters/numbers, and there has been another engine number system inbetween the current system and the number on your engine. Don't know when these numbers have been changed, but i doubt your engine is a 1982 model when it's got this enginenumber."
  7. #7
    david pasacreta's Avatar
    david pasacreta Guest
    Default "I have 1973 sailboat with a p
    "I have 1973 sailboat with a perkins which is leaking water from the water pump gasket.Is this an easy fix, is it just the gasket?"
  8. #8
    Default "Please help! We have a old 4-
    "Please help! We have a old 4-107 in our boat,and
    Im afraid its a dead soldier.So we found a good
    108 long block. are my parts going to be inter-
    chanable? ie.fuel pump,injectors,exc? thanks."
  9. #9
    Join Date
    Jul 2009
    Location
    Napa, CA, USA
    Posts
    1
    Default "I have a 4 236 perkins in my
    "I have a 4 236 perkins in my 1975 Morgan sailboat. It sat on the hard for a few years before we got it. I refilled the fresh water system with 50% antifreeze. I put in the kind that is compatable with aluminum. I ran it for a couple of hours with no issue. Then I did not run the motor for about 6 to 8 weeks. When I started it, it ran fine but started to overheat. I had good cooling water flow overboard. After it cooled, I opened the reservior on the front of the engine and discovered crystals that seemed to be antifreeze. They are about 1/8" + - in size and will crush and turn to a kind of grity mush between the my fingers. Some are harder than others but all will crush with very little effort. I have not found anything that disolves them ... so far. I removed the heat exchanger and found it packed with the crystals. I flushed the system and had the reservior and heat exchanger cleaned in a machine shop. I refilled the system and ran it regularly for about 6-8 months then let it sit for a few weeks. Once again it overheated next time I started it. Again I have the crystals. My questions are: Where do the crystals come from and what causes them? How can I make sure that they are all out of the system? How can I avoid them in the future?"
  10. #10
    Join Date
    Jul 2009
    Location
    Toulon France
    Posts
    2
    Default "As you refilled your system w
    "As you refilled your system with 50% antifreeze, maybe your fresh water is to be incriminated. i suggest refilling your cooling system with undiluted coolant(if not already done). My 4108 runs with standard car coolant and does not produce any crystals in the primary cooling circuit. It is not the same in the secondary system (sea water ) that needs to be cleaned of tartar deposits."
  11. #11
    Join Date
    May 2006
    Location
    Florida, USA
    Posts
    103
    Default "Not sure about the crystals,
    "Not sure about the crystals, they may be just left behind from the antifreeze evaporating. There may be a slow leak somewhere, check the water pump seals. Have you removed the thermostat and checked it. I would replace it and flush the system with it out by using a recirculation pump tied into the system. This can usually be done by tying into the hot water tank in and out hoses if so equipped. If not tie into the system somewhere else. Use a 20% solution of Muriatic acid and re-circulate it for 15 minutes. This will clean any organic deposits like rust, salt and minerals. The previous owner may have just used water and caused corrosion.
    I know you said that you ran the engine before with no issues but did you have it in gear and under load? My guess is the there is a block in the system that may let you idle it but would have overheated when under load. I have seen this quit often. Replace all the hoses to make sure they have not damaged inside. When you refill the system just use regular premixed 50/50 antifreeze. One other thing, have you checked your raw water pump impeller and are you getting good flow out the exhaust?"
  12. #12
    Thumbs up Re: hi can anyone help? i have a p
    Quote Originally Posted by kelly foyle View Post
    [email protected]
    try this link, they suply spares and also recon engines for 4107/8 plus others hope it helps
  13. #13
    Default Re: Is it a Perkins 4107 or a 4108
    [email protected]
    for all your 4107/8 spares and other perkins engines
  14. #14
    Default Re: hi can anyone help? i have a p
    hi, i have just bourght a 4108 as a spare for my cruser, it came with a couple of spare cav dpa injector pumps, (i paid 300 to get mine repaired 2 months age (sods law) so can be done) if you let me know numbers from your pump one of these might be good for you!!!
  15. #15
    www.parts4engines.com has them if you have not found one or try Pensacola Diesel They can rebuild the one you have.
Similar Threads
  1. perkins 4107
    By mchael in forum Perkins
    Last Post: 08-07-2010, 08:30 AM
  2. Perkins 4107 spares
    By bigman1 in forum Perkins
    Last Post: 09-10-2009, 07:04 AM
  3. PERKINS 4107 SN 7115420
    By a_dossett in forum Perkins
    Last Post: 07-18-2007, 05:36 PM
  4. Perkins 4107 and 4108 HP
    By jwh in forum Perkins
    Last Post: 08-06-2006, 09:09 AM
  5. Perkins 4107
    By iand in forum Perkins
    Last Post: 04-13-2006, 12:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
