MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
Thread: Prop shaft
  1. #1
    Default Prop shaft
    Hello new here.Could someone tell me how to take out the prop shaft on a 7.5 Mercury outboard motor?I need to check the seals.Thank you
  2. #2
    Join Date
    Oct 2018
    Location
    Mobile, Al
    Posts
    50
    Default Re: Prop shaft
    Check out this video by Dangar Marine. This guy is awesome & very helpful.
  3. #3
    Join Date
    Oct 2018
    Location
    Mobile, Al
    Posts
    50
    Quote Originally Posted by Kch View Post
    ...I need to check the seals.Thank you
    Hey, it occurred to me after posting my last reply that you may not need to disassemble the lower unit to do what you want. Have you tried just pressure testing the lower unit? You should be able to pressurize it & see if it holds the pressure. Don't quote me on this, but I think 10-15 PSI is all you need to test the seals. If it holds any length of time, the seals are ok. Just don't pump them up to some ridiculous pressure & blow the seals! Here again is a video from Danger Marine showing the process.
Similar Threads
  1. DAMMIT!! I bent my prop shaft and chewed up my prop 1980 Johnson 25 hp J25RCSA
    By Jhanratt in forum Johnson Evinrude Outboard Forum
    Last Post: 09-02-2016, 10:31 PM
  2. e15rcde prop bushing bad? prop spins on prop shaft while in gear
    By rockfisher805 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-15-2014, 01:09 PM
  3. Replies: 2
    Last Post: 10-08-2010, 10:25 PM
  4. Prop shaft and drive shaft Chrysler 6 hp
    By parker in forum Chrysler Force Outboard Forum
    Last Post: 12-23-2008, 12:06 PM
  5. Prop shaft
    By craig04 in forum Pleasurecraft Marine PCM Forum
    Last Post: 04-04-2008, 08:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
