Water in 8hp johnson gearbox oil.
Hollyj
Hello, I have found water in the gear oil and when i removed the impellar housing i found gear oil on the impellar. Also as i tried removing the impellar housung the drive shaft lifted out of the gears! Is this normal?
Its a 8hp johnson around 1998 i think!
Install a seal kit.-------Use 2 o-rings on the shift rod.----The drive shaft just slides out and slides back in , all normal.
