Results 1 to 5 of 5
    Sep 2007
    Enfield, Ct, USA
    18
    Default 1955 Chris Craft Alignment issue
    My 1955 17 ft Chris Craft Sportsman engine alignment is off on one side of the coupling by about .015. I know it should be under .003.
    It has wedges for up and down alignment on the engine mounts but I don't see any way to shift the engine side to side.
    Does anybody have any advice on how to shift the engine over?
    Dec 2006
    Chaumont Bay, N.y., USA
    5,806
    Default Re: 1955 Chris Craft Alignment issue
    Ayuh,..... Loosen the lag bolts, 'n give it a good Kick,......
    Sep 2007
    Enfield, Ct, USA
    18
    Have tried that. There is no play where the lag bolts go through the mount.
    Jun 2008
    Island Heights, NJ,
    3,082
    Use a file to widen the holes in the mounts, port and starboard, by what ever you need to get to 0.015". You will need to remove the mount temporarily to do this. Just make sure you support the engine well when you do this. A handful of 2x4 scraps will work. You will likely need to clean up the mounting surface on the stringers some.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    A bit late but,..... I might also suggest that a side to side misalignment might indicate a bent strut.
  1. 1955 Chris Craft fuel pump issue
    By jlash in forum Chris Craft Engine Forum
    Last Post: 10-09-2018, 05:13 PM
  2. Chris Craft Issue M-46s
    By ocitsalocs in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 05-06-2013, 05:51 AM
  3. bleeding the trim lines issue. '80 chris craft Advice would be appreciated!
    By bludvl49 in forum Mercruiser Sterndrive Forum
    Last Post: 04-22-2011, 05:30 PM
  4. Chris Craft 327 F pressure issue
    By sportn_wood in forum Chris Craft Engine Forum
    Last Post: 06-11-2009, 06:50 PM
  5. Chris craft with reverse rotation cooling issue
    By bcfdsq11 in forum Chris Craft Engine Forum
    Last Post: 04-29-2009, 10:47 PM
