Yes, with separate oil tank and all lines connected the fuel pump is a VRO system that is mixing oil and gas automatically.You pump the hose, ball gets hard, starts and runs then dies. The bulb is soft.
If you keep pumping while running or lift the pump above the motor is will stay running.
Yep, the bulb I replaced was only 3 years old. Checking the bulb is free for the OP and it sure sounds like the problem.The newer design bulbs are very short lived. They have crappy check valves and very poor rubber/ plastic composition.
