Go_Fast_DanO
I have a 2007 Honda BF50AKO that keeps falling flat on throttle advancement. I have replaced the fuel tank, fuel lines, primer bulb, in line fuel filter and added a large fuel water separator. I spent over $250 on new carburetor rebuild kit to include gaskets o-rings seals needles clips and Jets. I soaked the carbs and Chem-Dip and dumped two entire bottles of carburetor cleaner into every single hole and tiny passageway outside the carburetor and inside around the butterfly valve.
I reassembled everything according to the Honda shop manual for my motor to include the air mixture screw and float valve height. I also popped in three brand new spark plugs and had spark on all three cylinders when I tested against the block.
After a few seconds of cranking and choking the motor fired up and idled decent. After the engine was warm, I installed my carb synchronizer and got all three cylinders mirroring the number three cylinder. Next I started to adjust the air mixture screw and I got no response from the top carburetor while making adjustments. It did not matter if I turned it all the way down or six turns all the way out, there was no change in that cylinder. So I started adjusting the second and third cylinder and was able to get a rpm response so I shut the engine down for further investigation.
I pulled all three spark plugs out and found the number one spark plug was wet with fuel not water and the second and third spark plug had a nice light brown color on it like I am used to seeing. (Note.... when I pulled the original spark plugs out when I bought the boat the number one spark plug was black and the number two and three spark plug were light brown)
Not knowing exactly what was going on I disassembled the carburetor and rechecked everything to see if I possibly had debris stuck in my jets and I found nothing, then dumped an entire bottle of spray carb cleaner getting every single small passage way around the butterfly valve, and every opening until it was spewing everywhere. I then reassembled and tried starting again only to have the same problem.
After fumbling through the forums for a little while I could not find anything so I called my local Honda marine dealers within a two hour radius of me to pick their brains and this is some of the ideas that came up with:
1: check the float needle and seat to see if there’s any damage because it sounds like it is getting stuck shut. (I checked that and found no issues )
2: Clean the carburetor in and ultra sonic parts cleaner for a few cycles then clean the carb again with a bottle of carburetor cleaner and blow everything out. ( I do not have a ultrasonic cleaner so I’m not able to do that)
3: Bring it in and our certified mechanics with over 60 years of carburetor rebuild in experience will get you the right. Haha
4: pull the three spark plugs out and let the fuel dry out of the engine since it is probably flooded and pop in a new fresh set of spark plugs, set the mixture screw to 1 turn out as opposed to 2 1/8 turns out and give it a try. ( I did this yesterday and won’t be home until later to try and see if this works. )
So is there anything that I am possibly missing or anything you guys have experience that I have obviously overlooked?
