Well my head is officially spinning trying to sort out modern engine oils for use in 1989 Crusader 454s. My understanding is these engines have flat tappet cams vs rollers, and require higher zinc/phosphorus (ZDDP) levels than current energy efficient oils provide. Without it, the engines will wear faster. While there have been oils available that had higher ZDDP such as Rotella T3 and Chevrol Delo 400 LE, the formulations keep getting replaced with less ZDDP. I believe Rotella T4 may still have the higher levels of ZDDP, but they dropped the S rated for gas engines (maybe that's fine to use still)...
Originally, the engines called for SAE30 oil, but now Crusader recommends 15W-40. I can buy regular 15W-40 and use an additive to bring it up to the recommended levels of ZDDP (1200ppm), or continue to hunt for an oil that has the right level and that is rated S for gas engines.
So my question is, is there a current oil that is relatively easy to source (Walmart, local auto parts store, etc.) that has higher ZDDP, or is the only real option the additive now, and if so, does it work as well once mixed, with oil that comes with it straight from the factory? My engines may be old, but they only have 800 hours on them and run fantastic, so I'd like to keep them going as long as I can...
Once I solve this, I wonder if I can use the same oil in my 1989 Kohler 7.5kW generator, that also called for SAE30 oil originally.
Thanks for the help!
