1984 Crusader 270.
Some of this is memory from several years ago so may not be 100% accurate.
In 2015 I was getting the boat ready to launch. I had trouble starting one motor, when cold. If I played with it long enough, restarting, playing with choke, etc., it would stay running. I figured it was choke or carburator. Since I have not had much luck rebuilding carbs and since it was 30 years old I just replaced it. Didn't help. Then other factors interferred, I realized the boat wasn't going in, winterized it and forgot about it.
Fast forward to this year: Boat has still not been in, didn't want to let it sit too long without running so figured I would run and re-winterize. Engine would not start. Put gas in carb, would start and run for few seconds. Everytime, but wouldn't stay running no matter how many times I did it. I put an outboard bulb in the gas line and pumped to prime it. It would start, but stall after a few seconds. I discovered that if I started it and continously pumped the bulb it would stay running. Eventually, once it got warm, it would stay running. It now starts without priming it each time (except a push of the throttle, but no bulb squeezing), but stalls after a few seconds, unless I squeeze the bulb while it is running.
It is not the carb/choke (replaced). I thought maybe the fuel pump but it runs fine once warm (including revving up), although it is on the hard so I don't know if it will run full throttle under load. Seems to me if the pump is good enough for it to keep going, and rev, when warm it should be good enough to run it when cold. (of course I don't know anything for certain or I wouldn't be posting).
Any ideas or suggestions appreciated.
