Click for Chrysler parts and manuals!
Results 1 to 2 of 2
  1. #1
    Default Elecgtronic Ignition and what else?
    "71 LM318 - when I install an electronic distributor what else needs to be changed? Does it differ from say Pertronix and Mallory?
    Thanks, Friz
  2. #2
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    846
    Default Re: Elecgtronic Ignition and what else?
    Chrysler components would likely be....
    ECU
    COMPATIBLE coil AND ballast resistor
    Electronic Distributor
    Wiring Harness
    Constant output VR (if not already)
Similar Threads
  1. 1994 Evinrude 40HP ignition issue? Engine reaches max RPM with ignition off!
    By jeralmac in forum Johnson Evinrude Outboard Forum
    Last Post: 07-09-2011, 12:21 PM
  2. Ignition sesnor or ignition module?
    By ussoldier_1984 in forum Mercruiser Sterndrive Forum
    Last Post: 11-09-2010, 04:52 PM
  3. Honda bf100 ignition coil breaker point ignition
    By abentprop in forum Honda Outboard Archive
    Last Post: 02-24-2009, 09:31 AM
  4. Changing CDI ignition to coil Ignition
    By mitytim in forum Johnson Evinrude Outboard Archive
    Last Post: 04-30-2008, 12:43 AM
  5. Electronic ignition versus points style ignition
    By Curt Garrett in forum OMC Sterndrive and Inboard Archive
    Last Post: 10-14-2006, 06:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
