Ncflfishing
Been dealing with fuel issues, replaced several lines and filters and low pressure pump. Now one of the fuel lines out of the vst is dumping an ounce or so or fuel about every minute while idling. Is the pressure regular in the vst shot? I've taken the vst apart and cleaned with carb and choke cleaner and pb blaster, still seems to be over filling. Also line coming out of silencer over the intake sure does suck a lot of air, kills it immediately if plugged.. not sure if that's normal. Thank you in advance for any thoughts!
