willow
Really weird......
Went down to the boat to run the engines for the first time in 2018. Boat is on the hard, going to list it for sale. Has been sitting there for almost a full year....stabilizer in the tanks and full tanks....Batteries at full charge.
The stbd engine, (1991 Crusader 350cu in ), would crank but no fuel to carb. Suspected broken fuel pump. Possible plugged anti siphon. Something wrong at the fuel filter ??Anyhow, pulled the metal fuel line from the carb and cranked engine......no fuel coming out of line...
Left it alone and tried the port engine...same thing, no fuel to carb and would not fire BUT that engine is a replacement in about 2010 and has an electric fuel pump. Proofed the pump and found it was not working. Installed new pump and engine runs well.
Back to Stbd engine. Cranked the engine again and at long last fuel came out. Attached fuel line back on carb and engine runs well.
I have winterized my engines for the past 20 years, always the same way and this is the first time I have had an experience like today with the stbd engine...
Anyone have any idea why it would not crank out fuel for about 4 or 5 attempts to get it to run and finally we get gas out of the line, reconnect the line and the engine purrs.
I have never had anything like this ever happen and the only thing I can think of is and airlock. ( never heard of one),The anti siphon valve was changed about 3 years ago and the engine was running well when we put it on blocks October 2017.
I am suspecting the anti siphon valve again.......maybe gunk in the tank......think I will pull it off again and check it....bit of a bitch to get at it but I don't want to have the engine fail when in the water......the stern is about 8-10 degrees lower that the entire boat for water run off and that would put the starboard fuel tank at an angle and the fuel pick up ( changed in 2015 ) is at the rear of the fuel tank , almost the rearmost part of the boat.
If anyone has any other suggestions I would like to hear them.
