Click for Honda Manuals, Parts and Model Guides!
Results 1 to 11 of 11
Thread: will not idle
  1. #1
    Default will not idle
    1985 honda bf50 will not idle unless choke is on.Carb is clean and does not appear to have any vaccum leaks any suggestions?
  2. #2
    Default Re: will not idle
    Are you sure the carb is clean?
    Did you take it apart, soak it in carb cleaner and clean every teeny nook and cranny?
  3. #3
    yes it is clean,let it soak overnight I am starting to think maybe fuel pump when choke is turn off it seems to run out of fuel
    Thanks for the reply
  4. #4
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,974
    Have you tried keeping it idling by pumping the primer bulb with the choke off? If it will idle like that, it very well could be a weak fuel pump.
    Did you disassemble the carb to soak it? Can't really get them completely clean without removing the emulsion tube, idle mix screw and main jet plug and blowing through all the associated passages.
  5. #5
    have not tried pumping the primer bulb but will do that today and yes carb was completely disassembled when I soaked it
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,974
    Well, hopefully the prime pump trick will yield a result.
    Did you verify that the idle port orifice in the back of the carb throat will allow fuel to flow? Do you know that tiny little set of holes in the
    carb throat I'm talking about? There's usually three of them at the top of the "Venturi" passage (throat) clustered together near the throttle plate. The idle orifice is the only one that you can easily see when the throttle plate is closed. Sorry to keep coming back to carb questions but I am just thinking of things to check if the primer trick doesn't work.
    Good luck.
  7. #7
    that is something I was not aware of but will check out much appreciated
    Thanks Dean
  8. #8
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,974
    When I clean a carburetor, I use a spray can with it's little plastic "straw" to backflush the idle, transition and high speed circuits by placing the end of the straw over each orifice and blowing the s#^t out of them.
    This is best accomplished when the idle mixture screw, emulsion tube and main passageway screw plug are all removed.
    I then use the straw to blow the cleaner through each passageway while observing how it flows out each orifice.
    The idle orifice can be seen and accessed with the throttle plate closed. But, the transition and high speed orifices will need the throttle propped or held open to see and clean them.
    I continue to repeat the backflush and then foreflush operation until I get satisfactory flow from each orifice.
    Let us know what you find and good luck.
  9. #9
    Buy a new carb and be done with it, just my opinion. Keep the old one for parts. . https://www.boats.net/product/honda/...8f2e8ef831441c
  10. #10
    I have cleaned them thoroughly and I am about to try it again but I have I more question What does the vaccum diaphram that the vaccum lines from the carb do?
  11. #11
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,974
    I've not worked on that engine but the diaphragm is a "dashpot". Dashpots are used on carbureted engines to prevent stalling if the throttle is closed too quickly.
Similar Threads
  1. Low Idle / Idle in Gear Engine Dies Optimax 135
    By DavidSB in forum Mercury Mariner Outboard Forum
    Last Post: 05-11-2016, 09:46 AM
  2. 72 johnson, 25 hp, setting points, wot or idle? still dying at idle
    By dkonrai in forum Johnson Evinrude Outboard Forum
    Last Post: 01-13-2013, 09:28 PM
  3. Mercury 1994 135HP V6 BlackMax Idle Surgewonbt hold low Idle
    By tracsand in forum Mercury Mariner Outboard Archive
    Last Post: 11-18-2007, 05:02 PM
  4. 1974 evinrude 25hp hard start rough idle dies at low idle
    By mike gray in forum Johnson Evinrude Outboard Archive
    Last Post: 05-16-2006, 03:56 PM
  5. 1989 Evinrude 88hp Start at high idle Stall at low idle
    By carl spillman in forum Johnson Evinrude Outboard Archive
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
