Results 1 to 3 of 3
  1. #1
    Default Marcruiser 5.0 MPI acts like starving for fuel
    Hello,
    My boat just started acting like it is starving for fuel. I runs great for 3 to 5 minutes then starts acting like it can't get fuel. The engine doesn't die but the RPMs go up and down. I pull the engine back to idle at about 750 to 1000RPM and it idles fine. I wait 3 to 5 minutes run it up 3000RPM then the engine runs great for 3 to 5 minutes then repeats. I changed the $60 fuel filter in the fuel module and that didn't help. I have fresh fuel in the boat. What are your thoughts?
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,774
    Default Re: Marcruiser 5.0 MPI acts like starving for fuel
    Clogged anti-syphon valve at the tank?
    Jeff
  3. #3
    Quote Originally Posted by fastjeff View Post
    Jeff
    Thank you Jeff I will check that out. I'm really not sure.
Similar Threads
  1. starving for fuel?
    By glorious_one in forum Crusader Marine Engine Forum
    Last Post: 06-30-2011, 02:53 PM
  2. 1980 Mercruiser 470 acts like it's not getting enough fuel.
    By MILLER88 in forum Mercruiser Sterndrive Forum
    Last Post: 06-24-2010, 04:26 PM
  3. Starving fuel
    By zum in forum Mercury Mariner Outboard Archive
    Last Post: 08-05-2008, 03:13 AM
  4. Starving for fuel anti syphon valve or fuel pump
    By stigmen in forum Mercruiser Sterndrive Archive
    Last Post: 06-28-2007, 03:05 PM
  5. Replies: 3
    Last Post: 05-21-2002, 02:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
