If he hasn't broke it yet after 14 years, it's all good.
I would like to see what your crystal ball says!
No F^cking fancy stupid over complicated explanation needed.
Perhaps you could explain why that does not apply to your post #5, yet it bothers you regarding my post. Please enlighten us!
And hopefully you can figure out what a A and B and VP, SI, SA are and I bet a paycheck you wont be examining anything inside the drive unit...
I'm sorry Jack..... but I figured that it would be fairly clear in context.
A = Alpha drive, B = Bravo drive, VP = Volvo Penta, SI = Shift Interrupt and SA = Shift Assist.
If you like the boat and the price is right.............go for it!
Agree..... if the price is right, the worst case scenario may be that it would eventually need stern drive repair.
A 260 (I assume a 26 ft) then it either has two small blocks, two big block or one big block. Not knowing the actual year of the boat but considering what year it is now, I would say it has either one or two Bravo drives. Either Bravo I, II or III.
Again, I would like to see what your crystal ball says!
Perhaps read post #1 again.
dwgman55318 (the OP) is using the singular version of "motor", "transmission" and "stern drive"!
I would suggest getting a better understanding of what you are looking at before buying.
I fully agree!
Very few boats with outdrives have transmissions.
Not quite true. The AQ series VP (that's Volvo Penta for you, Jack) upper gear units are referred to as transmissions.
Since dwgman55318 did not mention what engine/drive combo the boat is equipped with, I posed the question in post #4.
A boat with an outdrive, The outdrive is the transmission so to speak.
If broken down into 2 or 3 components, the portion where the gear selection occurs would be the transmission.
(see above)
It shifts inside the drive itself by way of a cable system from the control box/shifter handle and there are two mechanical methods of how its shifts internal to the drive depending on the drive.
Alpha uses on method, Bravo's use a different method. Both accomplish the same goal. forward, neutral and reverse.
One other thing to remember, shifting can be done from around 1000 rpm (higher on occasion but not often and only in an emergency like hitting something) with no damage. Normal shifting occurs at the specification 650-750 rpm. The lower, the better for the drive.
I believe that this is dwgman55318's concern, and is his reason for this thread.
Inboard boats, boats with a long stainless steel shaft that exits the boat through the bottom of the boat aft of the engine will have a transmission, it will be mounted to the back of the engine similar to an auto. it again only has forward, neutral and reverse. if this is the type of system this boat has and it may have two, then shifting at higher than normal rpm will not bother it as much as a outdrive. The way a transmission functions (internal parts) is far more tolerant of higher rpm.
Perhaps read post #1 again........... dwgman55318 refers to "stern drive"!
