Results 1 to 10 of 10
  1. #1
    Default 1977 Evinrude 140HP water coming out of carburetor
    i have 1977 evinrude 140hp v4. I just bought the boat and noticed when i stared it , with the rabbit ears running water, water is coming out of the carburetor. Especially after i tilt the motor. I also took one of the spark plugs out (top right) and there was water on it. Im thinking some sort of gasket between the head and cylinder, like a car. New gasket replacement?
  2. #2
    Join Date
    Apr 2010
    Posts
    4,482
    Default Re: 1977 Evinrude 140HP water coming out of carburetor
    Check the head gasket on that cylinder. May be blown.
  3. #3
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    1,764
    Compression test, brother. Is it a saltwater rig?
  4. #4
    No sir, this is a fresh water rig. Also i did a compression test and got 90's on the left bank top and bottom. took the head off and found the gasket is bad and old. Dont think this motor has been serviced in a very long time! Compression on right bank, top 60, bottom 80. Took head off and gasket was completely wrecked, nasty, and rotted. Top of piston pitted,but cylinders were smooth (surprisingly). replacing the gaskets, bolts, impeller (think i spelled that right,the water pump), and pray for the best. Ill keep you updated!!
  5. #5
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    1,764
    Okay, good.....Boobie was right. Hope rings are not stuck. Might be good to soak 'em down with "blaster" while heads are off. You can get some 240 wet or dry and place on your wife's coffee table, or alternatively anything very flat. Then using moderate pressure and water, surface heads in a figure eight pattern until they look decent. Clean threads of the head bolts with a wire brush, or wire wheel. Clean block threads with a 30 caliber, barrel brush on a cordless.....or any drill. Blow out the holes. Then LIGHTLY anti seize the bolt threads and torque to specs in proper sequence. You will have to look up torque and sequence, but you don't have to be too fussy. Maybe Joe Reeves can help with the torque.
  6. #6
    Take the transfer port covers off and look at the rings on the pitted cylinder. Those motors like to break rings and use the correct size tap to clean threads.
  7. #7
    What is correct compression for the cylinders on this motor?
  8. #8
    I wish I could find a manual online for this damn thing...but Evinrude decided to get rid of the archive manuals!!
  9. #9
    Join Date
    Apr 2010
    Posts
    4,482
    Did you try Ken Cook.com in Milwaukee WI ??
  10. #10
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    1,764
    I would expect 110 to 125 on your motor. Wide open throttle......it needs air to make max compression. All plugs out and good cranking speed. Should build top numbers by 5th revolution. 10 psi max differential between cylinders. I'd allow a little bit more for certain known conditions and/or defects. Definitely use a tap on headbolt holes if it doesn't come apart nice and clean. I evaluate holes......should be able to twist in the bolts without a socket/ratchet.
Similar Threads
  1. 1977 140hp Evinrude
    By LV2BOAT in forum Johnson Evinrude Outboard Forum
    Last Post: 10-01-2011, 01:01 AM
  2. Temperature sender and water psi gauge On Johnson 1977 140hp
    By Chevytech49 in forum Johnson Evinrude Outboard Forum
    Last Post: 10-23-2010, 09:59 PM
  3. Fuel Mixture 1977 140hp Evinrude
    By H-Town Cobra in forum Fuel / Oil Mixture Ratio
    Last Post: 05-08-2010, 06:17 PM
  4. 1977 140HP Evinrude wrong waterpump
    By dan in forum Mercury Mariner Outboard Archive
    Last Post: 05-07-2004, 11:12 PM
  5. Evinrude 140hp 1977 no spark
    By Garry Saunders in forum Johnson Evinrude Outboard Archive
    Last Post: 01-26-2004, 09:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
