Results 1 to 4 of 4
  1. #1
    Default 30hp evinrude stalling when accelerating
    I have an 1986 30hp evinrude . Carb has been rebuilt . New fuel pump. Have good spark. Compression is 95 on both cylinders. It starts and idles perfectly . Once you start to accelerate it boys and dies like it's starving for fuel. But starts back up immediately. Could this be a timing issue. At a loss here . Any help would be greatly appreciated.
  2. #2
    Join Date
    Sep 2010
    Posts
    16,789
    Default Re: 30hp evinrude stalling when accelerating
    Could be your gauge , but 95 is low.-------Perhaps slow speed mixture is too lean.-----Perhaps throttle is opening too early.-----
  3. #3
    Thank you for your reply . I will check/ replace the by age and recheck. Gauge is my dad's and it's probably 30 yrs old. Thank you again.
  4. #4
    Want to thank you again . Just went out and messed with it again . I wrote everything down as far as settings when I rebuilt the carb . Seems I can't count . I was a full turn off on the , I guess what's called the air screw . The screw on the side of the carb. Seems to be doing great now . Hate and love when it's just little stuff . Thank you so much again .
Similar Threads
  1. 97 Oceanrunner 200 stalling when accelerating
    By n36511 in forum Johnson Evinrude Outboard Forum
    Last Post: 07-10-2018, 05:59 PM
  2. 2005 Mercury 60 hp 4 stroke surging at idle and stalling at accelerating.
    By Chadwick in forum Mercury Mariner Outboard Forum
    Last Post: 10-26-2016, 02:35 PM
  3. 2002 30HP Johnson Bogs Out When Accelerating
    By rboarderi in forum Johnson Evinrude Outboard Forum
    Last Post: 10-29-2015, 08:34 PM
  4. Mercruiser 3.0 Bogging and Stalling When Accelerating
    By Bangarng in forum Mercruiser Sterndrive Forum
    Last Post: 08-12-2014, 06:28 PM
  5. 1988 Johnson 88 hp stalling when accelerating from idle speed
    By mark etzler in forum Johnson Evinrude Outboard Archive
    Last Post: 08-07-2003, 01:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
