relicshunter
I have a 1996 90hp evinrude that has been running good for many trips out then it picked up a through exhaust backfire. The first trip I noticed a problem it was mid trip and it felt like it was missing and fiddling with it I found a lose plug wire and ran good back to the no wake zone and I noticed it again. Plug wire seemed good then heard a backfire. I checked spark and compression made sure everything looked tight and clean. Ran it again on the river and had no problems. Went for a ocean trip and had a few random backfirings.
I had a throttle adjustment that was not budging so I dropped it off with a local mechanic to look at both things. He took one side of the carbs off and said they looked real clean. It's a fairly new motor to me but it seemed well cared for. He put them back on and fixed the throttle problem and didn't get a back fire from it. I brought it back home and ran it before the next trip on muffs and it is still back firing. It has to warm up before it starts and it's random and at idle. I gave him a call, he said it's probably the power pack and he professed how much he didn't like this model for electrical issues. I replaced the power pack and it's back fires a little less frequently. I tried to consult him again and it seams he wants nothing to do with it. I replaced the coil packs as they looked a little cracked. I did skip the plug wires and I think maybe that lose wire and the backfiring have something to do with each other, and I should do the wires.
I've always heard that backfires through prop are electrical and through carbs are gas. Should I be looking at the carbs or dig deeper in the electrical?
