Half of the non return valve broke on my 290 outdrive. What is the purpose of this rubber valve (I assume to restrict water intrusion to some degree) and can I run it until I can fix it as long as I keep the engine running while its in the water?
-Robert
That part is labeled “non return valve” on that schematic.
Thanks. I'll replace it ASAP. I'm not sure when it broke but probably on my last trip out as I always look to see if water is spitting out of it when I flush it at the end of the day. BTW is that normal to have a bit of water spitting out with the exhaust? I assume so because its always been that way since I've owned the boat.
-Robert
