Haven't had to request help for some time but this has me totally stuffed.
Have a 1985 90hp Johnson. On last trip out started fine run beautifully. Idled about 200 metres from ramp when the overheat alarm started (continuous buzz which I have read in other threads is temperature ??). Checked for anything around pickup but all ok.Took it for a run at full throttle but still the same. Put it back on the trailer and put it on my to fix list. As it was due for a annual impeller replacement, I put a water pump kit and thermostat kit in. Whist I have the leg and thermostat housing off I stuck a garden house in all orifices and the water went in and out as it should.
Put it all back together and kicked it over for a few seconds to see if it turned. No problem but I left the ignition on by mistake as I went to get the garden hose to start it up which was about 3 minutes. When I got back to the boat the alarm was screaming which makes me think it didn't have a cooling problem but electrical. Turned ignition off went and had lunch came back to give it a run and no power to starter or accessories nothing. Put gauge on battery and fully charged. Pulled control to pieces and the buzzer is burnt out. Removed it but still no power. Played with the red lever on Primer solenoid and tried again and it starts, but I must of turned the lever to off as it ran out off fuel. Turned lever back to where it should be and tried again. Kicked over but before it started lost power again. There is 13v to the bottom of starter solenoid and the little fuse close to it is ok. But again no power to accessories. No clicking at solenoid. Nothing. A faulty solenoid would probably prevent it not engaging the starter but why would there be no power to accessories. The only other thing I should mention is I installed 2 new instruments. A tacho and GPS before my last trip when the alarm started, but I disconnected them to hopefully eliminate them as a problem.
Sorry for the long thread but I'm ripping what little hair I have out.
Any advice would be greatly appreciated.
