Results 1 to 3 of 3
  1. #1
    Default Mercruiser 5.7 dies at low rpms
    I have a 1994 ski centurion falcon with a mercruiser 5.7. First time this summer it was running rough and wild die here and there letting of the gas. We turned the idle up and made it through the night. I figured maybe bad gas so I put in a bottle of sea foam in the gas tank. Then the second time it started over heating (which was my impeller). But since it was already out I figured I would just cruise around and not go slow and watch the boat temp. So that was working fine until the boat just bogs down and dies at cruising speed. It wouldn't start for about 5 min and finally it started and I made it almost to the dock and it did the same thing. Waited awhile again and it fired up and made it to the dock. I brought it home and put in a new impeller but now when I running it at home it dies whenever I let off the throttle. I can kinda get it to stay running if I really slowly work it down to idle. I changed spark plugs, fuel filter, checked the coil and cleaned distributor ( is only two years old). I also checked and adjusted timing to eight. Any ideas before I pull the carb off and try clean it?
  2. #2
    Join Date
    Dec 2006
    Location
    Greenfield Me. USA
    Posts
    6,082
    Default Re: Mercruiser 5.7 dies at low rpms
    Ayuh,...... It's runnin' outa gas,..... donno why ya didn't start there,.....
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,129
    It is always best to use the tried and proven P of E..... (process of elimination).
    Check one item ONLY at a time.
    Change/replace one item ONLY at a time.
    When the P of E is used systematically and methodically, it won't let you down.
    Plus..... when you do find the problem (using the P of E), you will be better equipped to trouble-shoot in the future.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
Similar Threads
  1. Mercruiser MPI 383 6.2l -07 dies intermittently at low RPMS
    By olleman in forum Mercruiser Sterndrive Forum
    Last Post: 03-16-2017, 05:25 AM
  2. Runs great gets to higher rpms and dies
    By Kim Amann in forum Nissan Tohatsu Outboard Forum
    Last Post: 05-01-2016, 10:05 AM
  3. 8hp Johnson dies after running high RPMs for a few seconds
    By tapenick in forum Johnson Evinrude Outboard Forum
    Last Post: 03-08-2014, 10:04 AM
  4. 1979 mercruiser 228 dies at high RPMs
    By ncsalpena in forum Mercruiser Sterndrive Archive
    Last Post: 09-09-2009, 10:00 PM
  5. Big Problem 1985 Evinrude Starts Wont Idle Dies out at High Rpms
    By joe_froh in forum Johnson Evinrude Outboard Archive
    Last Post: 06-20-2008, 05:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
