Results 1 to 3 of 3
    Default 2005 Mercruiser V6 4.3L -water leaking into the engine
    I tried to start the motor but it would not start and it wouldn't crank.
    When I checked, water was mixed in with the engine oil.
    I opened the cylinder head and found that only one side had water and the head gasket was intact.
    So, I sent both cylinder heads to the machine shop for pressure test.
    The result was no crack in both the head. So they resurfaced the cylinder head and
    I assembled it back onto the engine.
    I went for a test drive and the engine would be fine for about 30 mins on full speed
    but after that, the water leaked into the engine again.
    I re-opened the cylinder head and rechecked for any cracks by doing another pressure test.
    The result came back the same with no cracks.
    On a hunch , I changed the intake manifold. Nothing had changed and the same thing happened with
    water leaking into the engine.
    FYInly the left side of the engine is filling with watter.
    Any ideas or suggestion would be greatly appreciated.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,964
    Default Re: 2005 Mercruiser V6 4.3L -water leaking into the engine
    Ayuh,.... Ya already posted this question in the Merc forum, so why post it twice,..??
    This just leads to confusion for those tryin' to help ya,.....
    yeah sorry about that. it was my first time posting and I didn't know it would duplicate.
  1. 1979 Mercruiser 898, water leaking into stern, engine not running
    By doninfosys in forum Mercruiser Sterndrive Forum
    Last Post: 06-28-2016, 08:33 AM
  2. Mercruiser 3.0 Alpha outdrive leaking oil out of water inlet???
    By gkm24 in forum Mercruiser Sterndrive Forum
    Last Post: 10-30-2014, 05:52 PM
  3. Problem with mercruiser 5.7L (2005) - water in oil
    By iliak6 in forum Mercruiser Sterndrive Forum
    Last Post: 10-02-2011, 07:50 PM
  4. 2005 Mercruiser 5.7L water in oil
    By leprican28 in forum Mercruiser Sterndrive Forum
    Last Post: 04-12-2010, 05:51 PM
  5. Mercruiser shifter arm leaking water into boat can you help
    By bchichi in forum Mercruiser Sterndrive Forum
    Last Post: 03-01-2010, 07:58 PM
