This does have a cdi ignition system. I do not have a workshop manual and yes I would appreciate a copy of the timing marks. However I did not remove the coils and did not temper with adjustments. Yes I did remove the timing belt and put it back on the marks. But it's been 4 years.
Also would like to point out that this NSS does not have any points in it, it looks like a disc brake caliper. The coils are on the side instead of what would be the pads, part of the shifter, which is what these coils sense, is a plate, that is between the caliper and again this would be the brake disc in a disc brake combination, when it is in forward or reverse, there is a plate/disc, when it's in neutral there is nothing in between. It must either generate some voltage when going from forward to neutral, or from neutral to reverse. Again the switch is not open circuit. It shows 278 ohms. This resistance never changes when going from forward to neutral and from neutral to reverse. I'm thinking since nothing happens it's bad. Cannot determine without test specs. Thanks.
