Click for Honda Manuals, Parts and Model Guides!
Results 1 to 21 of 21
  1. #1
    Default New water pump ordered......
    But could it be something additional? First time starting it this year today. Have not had boat out this season. Started 15 hp I. Deep barrel in driveway. Very little water coming out. Shut down
    the motor to save it. Changed impeller with the kit about 5-6 years ago. Boats.net is sending item in two day shipping. Could there be something else blocking the spray I should look at? 2006 SAHA 15 hp. Boat is going to go up for sale as we just donít use it anymore. So it has sat since last November. Thank
    you.
  2. #2
    Default Re: New water pump ordered......
    another question. Is there a bolt
    prep product that can be used in water? Or will the bolts
    that May come with kit have a thread ďlockerĒ
    on them? Or, last oar, do we just torque
    them and pray they never back out?
    Mainly asking about the bolts holding
    the lower unit in place. Thanks.
  3. #3
    I would have run a piece of weed wacker line through the tell tale to remove any dirt or grime that might be impeding the water flow. just keep pushing the line in until you cant get it to go any further. Might get foot or two inside. Just to be sure it isnt blockage before buying a new pump. Either way it is probably time you changed it out.
  4. #4
    There has to be a way to get some of these threads made into stickies.
    Here is a brilliant method to clear out the water line.
    http://www.marineengine.com/boat-for...ater-tell-tale
    A pair of 2002 Honda BF225s
  5. #5
    Weed whacker string had a tough time going in. The impeller
    has shipped already and will be here by evening
    Friday. I would start taking lower unit off
    but I have a tendency to misplace things.
  6. #6
    Didn’t quite follow the air blowing truck. To
    clear out water line. Where do you hook
    up bottled air to water line? Inside cowling
    and pull off hose from that nipple on the inside?
  7. #7
    The OP used a garden sprayer to provide pressured air. He took the nipple off the end of the tell tale and connected the hose to the wand of the garden sprayer.
  8. #8
    After I read it again, I realized motor was in water
    and prob didn’t take the side panel off.
    I used my compressor real low and immediately
    had bubbles. Started it then and what little water came out
    slowed to a dribble. I shut it off and put the hood and cover back on.
    Next is putting the new impeller
    and housing in late Friday or Saturday am. Any bolt
    prep needed?
  9. #9
    Where should I be seeing bubbles when
    blowing air back thru the tell tale?
  10. #10
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,332
    You should see bubbles coming out around the prop and the relief holes above the prop.
    When dropping the leg, remember that there is a bolt underneath the trim tab fin.
    CHawk 25 DLX
  11. #11
    Bubbles I saw came up from the front
    of the ‘shaft’, which I thought was weird.
    Came up fwd of where I thought I should
    see them. Exactly where is the water intake?
  12. #12
    Join Date
    Sep 2008
    Location
    Posts
    4,332
    I don't recall whether or not there are water relief holes on the front of the lower leg. There may be.
    Water intakes are on the lower leg between the hub for the prop shaft and the anti-ventilation plate and are covered by a black grill on each side.
    CHawk 25 DLX
  13. #13
    Parts arrived. Taking lower stuff off. Prop
    is off. Gear inside is out. Lower lube
    is thin and runny. Not good eh? Working on motor
    under umbrella in driveway. Motor is in up position.
  14. #14
    Well, thicker than water. Thicker than milk.
    I don’t remember the consistency of the old when
    I drain it off in the spring to add new. I didn’t do it in April.
  15. #15
    Impeller housing is back on. Trouble now is the shift
    linkage. I connected the a & b together and it moves, but the prop wont
    spin when in neutral. Prop is fixed like I. Fwd
    or reverse. I have tried moving the fixed
    nut downward with tightening the adjusting nut
    against it. Didn’t work. Any ideas?
  16. #16
    I don’t have any lower gear lube in housing at
    this time. Motor is raised. I have tried spinning prop
    in lowered position as well. Still stays put.
  17. #17
    Join Date
    Sep 2008
    Location
    Posts
    4,332
    Go to the link below, load the PDF file, expand it, and page down to page 12-5 through 12-12 and follow those instructions.
    http://planbmarine.com/wp-content/up...BF200A-BF2.pdf
    CHawk 25 DLX
  18. #18
    Join Date
    Sep 2008
    Location
    Posts
    4,332
    CHawk 25 DLX
  19. #19
    Last time I had the prop shaft holder/assy
    out, two little pins fell out, one in two pieces.
    I finally had the shift linkage connected with both upper
    and lower in neutral. But the prop still wouldn’t spin
    in neutral. These pins prob have something to do with it.
    Going to take prop shaft holder to closest dealer
    Monday. Hope they can point out what’s missing and where it goes.
    I have the shop manual here in front of me. This is an area where
    I have never dabbled it before.
  20. #20
    I took a foto of items here in the house
    with my fone. Hope image comes
    up with this post.
  21. #21
    I took the image with my iPhone 5s and tried
    to post it here. It won’t bring it to this
    area. Not sure about things like these. I am computer illiterate. ��
Similar Threads
  1. need more rpms, i ordered new prop
    By coolbri70 in forum Propeller Selection and Replacement
    Last Post: 07-30-2014, 11:22 PM
  2. 10 hp sportwin with new water pump wont pump water to head
    By 85stang in forum Johnson Evinrude Outboard Forum
    Last Post: 07-02-2012, 12:14 AM
  3. Impeller replacement have I ordered the right kit
    By ycart0 in forum Mercruiser Sterndrive Archive
    Last Post: 02-23-2009, 09:32 PM
  4. 1992 Suzuki 225 water pump doesnbt pump water
    By rainey230 in forum Suzuki Outboard Archive
    Last Post: 07-15-2008, 06:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
