livinloud11
Hello all, im really hoping I can get some help with my issue!
Motor is a 1987 Evinrude 88 SPL on a 16' neptune 160. The other day I made it back to the boat ramp when turning the key didn't do anything but turn on my gauges. I'm SOMETIMES getting power to the red 12v wire behind the key ignition. I also SOMETIMES notice my volts dropping when turning the key, but nothing is happening. In line fuses are good.
The wiring on my starter solenoid (i've tried 3 but I just ordered a new one to be safe) is as follows. Top post is getting power from battery, power from the wiring harness (fused), and a single line from the top post to the fuse panel box(?). 1st small post down has two brown wires connected. Next small post down is ground, and last post is power to starter. The flat part of the solenoid is facing my starter.
I have bypassed the neutral safety switch and still cant get it to fire. Does anyone have an ACCURATE wiring diagram for my motor? see attached pictures because I don't think it is right, but it has been working like this for over two years now. (I didn't originally wire it this way). The fuse box (?) is only getting power with the white wire attached to it from the top post of the solenoid.
