I recentury purchased a 15 ft whaler with a 2013 60 HP Yamaha 4 stroke. When I bought it the engine only had 53 hours on it and it now has 69 hours and was running great. The other night it started to stutter and shut off. I figured out that there were some gaskets on the gas tank that was letting air in and the fuel line was basically sucking more air than gas, so I switched to one of my other external tanks. The rest of the night it ran fine. The next time I went out the engine would only get up to 4,000 RPM’s and seemed like it was running louder and struggling. It’s pumping plenty of water and never stuttered or sounded like it was going to stall. Back at the dock I tested it in neutral and it had no problem getting up to 6,000 RPM’s. The previous owner did install an in line fuel/water filter. Any advice is appreciated as I don’t know much about outboards, more of a sailer. Also I have been using fuel treatment and just filled the gas tank a few days prior from a station that is pretty busy so I’m guessing it’s not a fuel issue.
