Results 1 to 16 of 16
Thread: Wet Plugs
  1. #1
    Default Wet Plugs
    Hi, I got a problem with wet spark plugs, how would you guys solve the problem and get the motor to start?
  2. #2
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,368
    Default Re: Wet Plugs
    Wet with water or wet with fuel?
  3. #3
    Join Date
    Sep 2010
    Posts
    17,078
    What motor ???-----Any other trouble shooting done ?----Did this " no start " condition develop suddenly ?
  4. #4
    Hi Vic ad Racer one, thanks for the response it's wet with fuel and could not start it's a 25 hp and was wondering if any way to fix it? I got it running at home again by changing the plugs and spraying carbarator cleaner.
  5. #5
    Join Date
    Sep 2010
    Posts
    17,078
    A 1953 -----1969 ----1985 or 2005 model.----All different motors.
  6. #6
    Hi Racerone, it's a 1988,25 hp evinrude long shaft.
  7. #7
    Join Date
    Apr 2010
    Posts
    4,523
    What's the compression on it ??
  8. #8
    Join Date
    May 2008
    Location
    Posts
    1,368
    Quote Originally Posted by Kailio View Post
    Rope start or electric start? If you quote the full model number ( model number , not serial number) folk know exactly what you have!
    It sounds as though it is flooding.
    Maybe the carb float valve is not seating properly.
    Maybe you are over priming if it's a rope start model with a manual primer pump
    Maybe the electric primer valve is set incorrectly if it is an electric start model ( Red lever should be in in line with the solenoid)
  9. #9
    Thank you Vic, it's a rope start and just got flooded and started it the next day with carb cleaner and cleaned the plugs. Was wondering if that's the right way to fix the problem or If there's a better cleaner?
  10. #10
    Join Date
    May 2008
    Location
    Posts
    1,368
    Unless of course there is a problem with the carb float valve I suspect the long term solution is just getting to know how best to operate the choke/primer pump when starting.
    If you do flood it return the choke to its normal running position and crank the motor at full throttle ( provided there is not a interlock to prevent that) until it shows signs of life. In extreme cases take the plugs out and crank it to clear the cylinders of excess fuel Clean and dry the plugs before refitting.
  11. #11
    Okay Vics, sounds about right probley I over choked her, she started the other day and this morning I couldn't start her again I repeat the prosses of the plugs with the cleaner and gave up. What brand of plug do you recommend I should buy, I running the champion L77Jc4 right now or is that alright?
  12. #12
    Join Date
    Apr 2010
    Posts
    4,523
    Never did get an answer on compression ????
  13. #13
    Hi Boobie, thanks for the response but I think t he compression is okay, didn't take a test tough but I think what Vic is saying is the cure about the choke. Went out today and tried not to over choke her.
  14. #14
    Thank you Vic, the motor is okay I pull her twice without choking her and pulled the choke once and she started and didn't choke her all day after that, I do a lot of turning off the motor during the day and use to choke her while starting and that was the problem of the hard starting.
  15. #15
    Join Date
    May 2008
    Location
    Posts
    1,368
    The preferred plugs are Champion QL77JC4 ( gapped at 0.030") but the "Q" only signifies inductive suppression. Your motor will be OK with L77JC4.
  16. #16
    Thank you Vic, will try to go out on the water today and try to start her, when I try will I stay with the method or choke her once before starting and pulling it at full throttle?
Similar Threads
  1. Replies: 6
    Last Post: 07-25-2017, 12:51 PM
  2. Spins without spark plugs. Wont spin with plugs installed. 96 SLP 112 HP
    By Stephen Houmard in forum Johnson Evinrude Outboard Forum
    Last Post: 04-12-2015, 07:27 PM
  3. Replies: 7
    Last Post: 02-03-2013, 09:42 AM
  4. Marine spark plugs vs normal spark plugs
    By bgallan in forum Johnson Evinrude Outboard Archive
    Last Post: 06-20-2009, 01:07 AM
  5. Mnual syas 3 plugs but i really have 5 popped plugs and oil leak
    By Grant Hatchett in forum Mercruiser Sterndrive Archive
    Last Post: 06-20-2008, 11:34 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
