Long time lurker, 1st time poster. We have a 23ft 1977 Chris Craft Lancer Overnighter. It had a AQ280 s/p with a Chev 350. Looking thru CC specs on the boat they say it weighs about 4000lbs, we think its more than likely to be around 4500lbs. They are no scales local to really confirm its weight. The engine is a Chevy 350 with approx 260hp. We recently swapped the lower to a 290DP(1.95:1). The lower came with a mix set of dou props that are in bad shape. The front prop is a bent and nicked up B8, and the rear prop is a B7, which is in better shape. We did run these props to see at least where we stand. At WOT we hit 39/40mph(GPS) and maxed out at 4000rpm. Originally with the single prop, we were running 14.25 x 21 pitch getting 4500 rpms, and 39mph. I want to see what folks recommendations might be for "B" series Duo Props? Also, does anybody know what the RPM differences are between each set might be? Has anybody tried going from B series to J series props? Also has anybody, tried Power Tech Props vs V/P props. Thanks, Ken
