60 up big foot
Mito35
Just purchased pontoon boat with a 60 up big foot Mercury. I know nothing about except I think it is a 2003 year. Model is 1060412AM. Serial # is OT622492. My first ? Is where is the fuel filter? Terry
Your serial number is coming up as an 2003 60-HP MERCURY NITRO TRACKER ELPTO / Model Number 1060412AN (3 CYLINDER / 2-Stroke).
http://www.marineengine.com/parts/mercury_marine_parts/sn/OT622492
For the Fuel Pump, Electric system, item number 18 will be the fuel filter design, http://www.marineengine.com/parts/mercury_marine_parts/sn/0T622492/1060412AN/3371_80
For the Fuel Pump, Manual system, item number 22 (Old # 35-891642T03 which superseded into #35-8M0063726) would be the fuel filter design, http://www.marineengine.com/parts/mercury_marine_parts/sn/0T622492/1060412AN/3371_90
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=891642T03&_sacat=0
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=35-8M0063726&_sacat=0
http://www.marineengine.com/newparts/part_search.php?part_num=35-8M0063726
Thanks for the information, This helps so I know now what service manual to get as well as order parts. Terry
Tracker by Mercury model 1060412AN SN 0T780816 need to replace water pump. Purchase the kit 46-8M0113799 - Water Pump Repair Kit
Issue: with removing lower unit, while unscrewing 2 bolts on each side and one nut above the prop i can't figure out how to loose the shifting gear shaft pls look at the picture below
https://1drv.ms/u/s!AiOOAOMl1OCYgqFSznlM0KPnoBJbwA
