Thanks2X on the wires....
most of the other 'auto' parts listed may work but they are false economy....the marine caps usually have brass terminals and many need a gasket....same for the rotor's conductor and the plugs for marine use typically have a plating that keeps corrosion in check....
Ayuh,.... Automotive wires are to short, as they're routed over the motor, on boat motors it's down, 'n around,.....
