StevensPoint
Hi All,
My 1984 60hp Mariner (3cyl, serial: 6429699) mounted to a '78 Forester 15ft Tri-hull has been giving me problems. The motor starts, idles and runs at low speed just fine all day long. If I go WOT it pops out of the hole immediately. I then back off to 3/4 throttle and it cruises on step just fine for about 1 minute, then it loses significant power and acts like one or two cylinders intermittently just stop firing. Then, like a light switch they are firing again. It's bad enough that the boat can't stay on step. This goes on for as long as I keep it above 1/4 throttle. I don't do it for long fearing that it might be a fuel delivery problem although the immediate on/off nature of it makes me think electrical. If I drop back to 1/4 throttle or less it seems to run fine again.
Based on posts from folks with similar issues I have done the following:
1) New stator 5 years ago to fix no-start condition.
2) New spark plugs multiple times (NGK BUHW gapless plugs).
3) I asked my wife to constantly pump the primer bulb while I ran it up to 3/4 throttle. Maybe slight improvement??? not really though.
4)
6) New spark plug wires this week.
7) New coils (3) this week.
I only run fresh, non-ethanol gas mixed 50:1 with synthetic oil. The prop is a little dinged, but it seems to run fine until it seems to drop a cylinder. Water squirts out the hole. I have not measured any water or cylinder head temps.
Where do I go from here? Any help is greatly appreciated!
4)
I swapped the entire fuel tank, line and primer bulb with another unit - no improvement.
5) New CDI 2 years ago attempting to fix current problem.6) New spark plug wires this week.
