Prop shaft in out play
Roadking1
Hi my prop shaft on my 1979 140hp has a Lot of play in and out feels spring loaded but won't go all the way into drive unless I push shaft in but spring load just pushes it back out any ideas
And how much is " a lot " here.----Post a number !-----Yes the clutch dog is spring loaded.--------Are you testing with the lower unit off the motor ?----Or with shift cable off at the top ?----Lower unit off recently for water pump work ?----Checked condition of the gear oil ?
