I have milky oil coming out of this hole!
robgray
engine1.jpgI have 1983 Mariner 9.9 motor. Took it out yesterday and it ran great. Then taking the boat out and while it was sitting on the trailer I noticed milky oil coming out of that hole mark above. Can I get recommendation on this. Thank you
You have water in your lower end, know you have to determine where it is coming from. Sorry for the pun but I am in the same boat with the used boat I just purchased. Could kick myself for not taking along a screw driver to check that before buying. I have changed mine, but before that I replaced all three screws, the others did not have seals. Know I still have the issue so will have to replace all seals. Best to you.
That may well be normal.---And the oil that is mixed with the gas may be leaking out.------Gearcases can be pressure tested to find leaks if there are any !!
