Results 1 to 9 of 9
  1. #1
    Default Johnson 225 ocean runner
    Help, We ran out the other day and the engine ran perfect. Fished for a while and started our way in and the engine started to jump on the engine mount. It would do it about every 50 yards or so. Slowed down to about 1700 rpm and it went away. I don't know if it was a miss or something else. I had it looked at and was told my prop hub had spun. Had that repaired and was told they would sea trial the boat. They did not sea trial it. Paid the bill and went down to work on some other things. My son said I think we need to test the boat before we plan on going out, so we launched and went out. Boat is doing the same thing. When under way at slow speed it runs fine. Get up on plane and jumps like you have hit something. Any help would be greatly appreciated.
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    3,144
    Default Re: Johnson 225 ocean runner
    Try pumping the primer while underway, Also check the condition of lower unit oil
  3. #3
    They replaced seals in lower unit plus prop hub.. Also water pump. What would I be looking for if it does change the way it ran.
    Thank you
  4. #4
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    3,103
    Its jumping out of gear...need to make sure shift rod height was set correctly...
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  5. #5
    Thank you.
  6. #6
    Join Date
    Apr 2010
    Posts
    4,323
    Could also be an ignition miss.
  7. #7
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    3,144
    good01 Keep usposted
  8. #8
    Will do, should find out more tomorrow.
  9. #9
    So found out today that the top of the number 1 piston ring gland is broken. So I guess a re-power is in order. Thank's for the help.
Similar Threads
  1. 1995 Johnson 115 Ocean runner
    By dhearn0513 in forum Johnson Evinrude Outboard Forum
    Last Post: 12-05-2013, 06:20 PM
  2. 150 johnson ocean runner
    By brent14 in forum Johnson Evinrude Outboard Archive
    Last Post: 11-17-2008, 09:53 PM
  3. 1996 Johnson 200 hp Ocean Runner
    By Cardiac Arrest! in forum Johnson Evinrude Outboard Archive
    Last Post: 08-23-2008, 03:11 PM
  4. 1996 johnson ocean runner 200 hp
    By wrrogers in forum Johnson Evinrude Outboard Archive
    Last Post: 03-24-2008, 03:46 PM
  5. 200 Johnson Ocean Runner
    By SC in forum Outboard motors archive 2000-2004
    Last Post: 02-21-2003, 06:34 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
