MrTimsmith
What I want to know if anyone can help diagnose the issue and point to a solution which may include repair or replacing the existing engine.
It is a 1992 mariner magnum 40hp 2 stroke outboard.
Long story short I've recently been doing up an older outboard and boat owned by family, and got to the point of taking it for a test drive (will post a full list of repairs as a larger paragraph underneath this).
It ran perfectly if a little smokey for the first half hour until it started coughing and lost power, I then limped it back to the launch ramp 700m away and had a look under the cowling.
Unfortunately the bottom pistons had stopped firing and the top of the spark plug is partially mangled. There are visible metal filings in on the piston and some metal damage I think.
I might add the telltale was spitting water like a horse until the loss of power upon which time the telltale slowly decreased slowly to be almost a slow drip by the end of the 700m limp home although the water wasn't hot that was cycling through.
Up until now I have completely relied on my own skills to repair an engine that was seized and hasn't run in 4 years.
A full list of repairs are as follows.
Degreasing and regreasing all grease points,
Replaced spark plugs,
Cleaned carburetors and fuel lines of water dirt and old fuel,
Dismantled cleaned and rebuilt starter motor,
Replaced power cable for tilt trim motor as it was short circuiting,
Replaced fluid in trim tilt system,
Replaced fuel line to fuel tank due to perished plastic,
Drained lower unit and refilled lower gearbox reservoir,
Checked from oil seals and removed debris,
Replaced damaged Impeller,
Replaced battery terminals,
Completly rebuilt wheel bearings on trailer,
Unseized engine using ATF fluid as a penetrating soaking oil in pistons and turning the flywheel by hand with braker bar until easy by hand,
Replaced seized pivot tube and salvaged steering cable from pivot tube,
Started engine with earmuffs with no troubles and decided to take it for a good run to get everything lubricated.
My first post,
Will answer any questions with as much detail as possible.
Cheers for any help.
Mr Timsmith has
My first post,
Mr Timsmith has
