goingmach_1
New poster here. Did a search and a few hits came up but really none with a resolution. I have a used BF 9 on a 12 foot zodiak. Had it a couple of years and in the beginning, ran great. Last fall with 2 people in the boat I was running down the river for about 30 minutes at 3/4 thottle as WOT causes the bow to dig in and actually slows the boat. I tried adjusting the engine angle by putting the pin in different holes but no change. If you get the person up front to lean way back sometimes it gets up on plane, but whatever, thats besides the point. We stopped and had a shore lunch, and on the way back the engine started to stutter, again at 3/4 throttle. It did it once, then like 60 seconds latter, again and then 45 seconds again and the frequency got shorter and shorter till it just finally died. You could start it, it would idle for like 20 sec then die. Thats all it would do. Rowed to shore and pulled it out of the water. End of the season.
Background. That season (spring) I cleaned the carb and noticed what I thought was a clog in some of the little holes in the Main nozzle. So I ordered a new one. Also changed the fuel filter. Dumped out the fuel tank and changed the oil and filter. The reason I did all of this was there was water in the gas from winter storage and so I dug into it a little deeper.
This spring i took the cowls off and wiggled ever wire I could touch or see. The only thing suspicious was the wire on the oil pressure switch felt a little loose. Pulled back the rubber cover and crimped the female connector so it was nice and tight. Placed the engine on a stand in the garage with a water muff on it and ran it like 20 minutes throttled up quite a bit. All seemed fined. Felt like I may have solved the "problem".
First outing this year, engine starts second pull, idles perfect, shifts nice, but once out on the water, same thing. After about 10 minutes that intermittent stutter returns. Then eventually it stops. Fuel system if fine. No water in the gas, lots of water coming out the hole like its supposed to, the green oil pressure view glass is green, squeezing the primer bulb does nothing, more importantly does not help it run. Engine oil level is at the full mark.
So, seems I am not alone with this intermittent very annoying problem.
Anyone out there have suggestions? Or solved this kind of issue?
Any help most appreciated.
Sitting on the dock wondering what to do!
