LED Indicator Lights
TritonFisher
Does anyone have ideas on replacing the small red indicator lights on a large panel? Some of them work, while others do not. I know for a fact the device works connected to it (i.e. master power, bilge, etc.) but the little red light not working is annoyong! They seem to be held in with large amounts of adhesive and are very small wires. Any ideas are appreciated!
If what you have isn't doing so well, I'd suggest replacement with something else.....go to the local marina(s) and see what works in the majority of the boats similar to what you have....some prefer bulbs but most have 'upgraded' to LED indicators.....there's also a wide variety that can be obtained online.....
The key drivers are supply voltage (12VDC), connection method, and mounting method....as a rule, you get what you pay for.....so a $5 indicator will likely outlast the $2 one...
