Yes, but I DIDN"T put it back onI wouldn't think so, the anode is a sacrificial piece of material, so the rest of the engine does not begin to corrode.
We may need some more information in order to help. You mentioned that the spark plugs have “died”. Have you physically removed them and checked for spark at each cyclinder? If so what condition are the plugs in? I agree with the above comments regarding the hydrofoil (properly installed) will not affect how the engine runs. That being said it can and will improve performance but it’s not directly related to either the ignition nor the fuel system on the engine.
If you put the old plugs back in will it start?Again, I don't think the problem is fuel, as I said, when I replace with new plugs, it's start's right up
Wow, if it would start with the old plugs, I wouldn't have a problem
I think you're the only one that thinks both plugs are dying at once. Plugs rarely go bad. But anything is possible I guess.I had spare plugs with me, but thanks for the obvious. That still doesn't help me with why both plugs are dying at once.
