Results 1 to 3 of 3
    Default 1997 OMC 115TJEUC carb rejetting issue
    Gents, I have the above engine (turbojet drive) and am rebuilding the carbs. (carb bodies 335829-ET). The issue I have is that the jets don't match what was purchased from an OEM parts supplier. Idle air orifice pulled out is #36. New one is #39.
    High speed fuel orifice pulled #67C. New jet is #68C. Carb casting indicates 8/94 manufacture. (idle fuel orifice matches with #22) Set up is dual carb, V4 90deg 115HP. Please advise. Thx!!
    Sep 2016
    Smyrna, TN
    236
    Default Re: 1997 OMC 115TJEUC carb rejetting issue
    You can look up your own parts specs on OMC SystemMatched Lookup & look at parts schematics. They list Turbo jets parts list. After checking that the parts you quoted are correct. 68C HS, 22 LS, & 39 idle air bleed. Not much difference in the .001 HS & someone might have just wanted to richen the idle some? Idle air jets have to make a bigger move to have an effect on the running quality.
    Talking Re: 1997 OMC 115TJEUC carb rejetting issue
    Quote Originally Posted by t2stroke View Post
    Nice! Thanks a bunch. Thanks for the "OMC SystemMatched" info as well. I will have to dig around in there.
  1. Dumb cooling question 1997 115TJEUC
    By sportsguy0629 in forum OMC Sterndrive and Inboard Forum
    Last Post: 10-08-2016, 09:57 PM
  2. 1997 Mercury 125 2X2 - Rejetting / Recarb ?
    By Tomoka in forum Mercury Mariner Outboard Forum
    Last Post: 04-15-2014, 08:00 AM
  3. Rejetting 1984 Johnson 70HP
    By financeguy in forum Johnson Evinrude Outboard Forum
    Last Post: 04-01-2012, 11:23 AM
  4. rejetting carbs on M70B
    By kr308 in forum Nissan Tohatsu Outboard Forum
    Last Post: 10-04-2011, 10:39 AM
  5. 1997 200 shifter issue
    By gmiv in forum Yamaha Outboard Archive
    Last Post: 12-22-2008, 08:50 PM
