Results 1 to 5 of 5
    Default 1988 Johnson SPL 48hp J48ESLCCC Drive shaft shim question.
    Hey you guys!
    Does anyone know if I have to shim the driveshaft on the motor in the title? I don't think there was one there when I took it apart. If I don't what is the worst that can happen. I guess I should ask, how can I tell if I need to shim it?
    Thanks for any help you can give.
    Madboater.
    Apr 2010
    4,323
    Default Re: 1988 Johnson SPL 48hp J48ESLCCC Drive shaft shim question.
    What did you take it apart for ?? According to the parts book it does have shims.
    Nov 2011
    tennessee
    3,103
    Worst that can happen is you buy a $400 gear set...you need driveshaft shimming tool to know if it needs/how many shims..
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
    I took it apart because the vertical driveshat bearing disinegrated and then the forward and pinion gears got torn up. \
    It was not a good noise. Anyway, I have the new gears, bearing and some other stuff that got ruined so now I have to figure out how to put it back together.
    This is what I call fun.
    Apr 2010
    4,323
    Read post # 3.
  1. 1983 Johnson 25 hp drive shaft question
    By ABrock in forum Johnson Evinrude Outboard Forum
    Last Post: 05-17-2016, 01:04 PM
  2. Johnson/Evinrude drive shaft question
    By Toxophilite in forum Johnson Evinrude Outboard Forum
    Last Post: 01-26-2016, 06:47 PM
  3. Replies: 8
    Last Post: 07-02-2015, 12:36 PM
  4. formed strut shim in place - question on shaft/cutless play
    By bobct in forum Crusader Marine Engine Forum
    Last Post: 04-28-2012, 07:12 AM
  5. 140 hp Johnson 1989 Looper Shim amp Oil Question
    By souls in forum Johnson Evinrude Outboard Forum
    Last Post: 03-05-2010, 09:34 PM
