bmartsjohnson
I have a little 17 foot Lowe aluminum bass boat with a 1988 60 HP Johnson. It was a VRO but the previous owner converted to gas and oil mix. I used it all last year with no problems. This year I started pulling my son on a kneeboard and now it seems the load is possibly causing an overheat condition. It has only been in freshwater. The motor will run fine for about 45 mins or so and then the alarm comes on. Water is coming out of the tell tale. If I take engine cover off the exhaust port and head are pretty hot. Water does not sizzle though when I throw some water on head and exhaust port. After about 15-20 minutes the engine will cool enough for motor to start and then I can run it again for roughly half hour. I plan on replacing the water pump and maybe thermostat as this seems like logical place to start. Could it just be that the load is to much for that engine or should it be able to cool itself no matter. I read somewhere that there were TSB's for this model engine regarding placement of the cooling line to upper par of the exhaust port. If anyone has any suggestions or has had this happen to them please give feedback.
Thanks!
Thanks!
