Results 1 to 5 of 5
    Default New member seeking help Yamaha F60 TLRC
    Engine will not turn over; I have replaced the starter, solenoid, checked battery-new, etc. and do not know what to do next. The starter and solenoid is getting power, but it will only turn over one time.
    Please help!
    Thank you,
    Ernie
    Apr 2016
    barnegat NJ
    3,144
    Default Re: New member seeking help Yamaha F60 TLRC
    Pull plugs,to see if she will turnover by hand
    "johnnygjr 615015 "Pull plugs,to see if she will turnover by hand"
    Ok, I pulled the plugs and turned it over with the ignition switch; while it did turn over, it was awfully slow and sounded awful! Nonetheless, it did turn over. What next or what do you think???
    Thanks so much for your help.
    Ernie
    Apr 2016
    barnegat NJ
    3,144
    Borrow a borescope and look inside the cylinders with the pistons at the bottom of the cylinder
    By the way, the prop won’t turn. Seems as if the motor has seized up. Don’t understand. Was running fine when I turned it off?????
    HELP!!!!!
  1. Yamaha 225-seeking assistance
    By vicbc37 in forum Yamaha Outboard Forum
    Last Post: 09-23-2014, 06:25 AM
  2. Replies: 0
    Last Post: 07-17-2013, 10:07 AM
  3. 2004 Yamaha 40HP TLRC Help with choosing prop
    By davio47 in forum Yamaha Outboard Forum
    Last Post: 02-18-2013, 05:31 PM
  4. Replies: 1
    Last Post: 10-31-2010, 02:54 PM
  5. Seeking El Pescador
    By wharfcreek in forum Volvo Penta Gas Archive
    Last Post: 04-10-2008, 12:15 PM
