Results 1 to 5 of 5
  1. #1
    Default Pull cord locked up
    We have a 96 yachttwin 9.9 two strokewith electric start. Tried to start it today and it spun up then justlocked up. I thought I had a hydro lock so I took the plugs out. Notthat. Solenoid would not engage. I wacked it and it fired right up. Iwanted to make sure I could start the motor out on the water so Itried the pull starter. It's locked up tight. Won't budge. Motor willnow start with the starter. but not the pull cord. What's up? Any thoughts?
  2. #2
    Join Date
    Nov 2011
    Posts
    2,202
    Default Re: Pull cord locked up
    Does that model have a recoil starter lockout?
  3. #3
    Yes, I believe it does. I looked at the parts list and I do have a lockout link but it's just hanging free and I don't see anything to connect it to. It's free at the top. Don't know what the bottom of it is connected to.
  4. #4
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    933
    Quote Originally Posted by fdrgator View Post
    My thought too. There is a little tab on the pull rope recoil that will catch if the motor is in gear. It's a pretty close fit to the notch it engages so if your shift linkage is off a bit the lockout can engage. The 'Whack' you gave it may have dislodged the lockout.
  5. #5
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    16,509
    The 96 models have a recoil above the flywheel.-----Locked by a rod that connects to shift linkage.-----In gear you can not pull the cord.----If you can not pull in nuetral repairs /adjustment to the rod is required.
Similar Threads
  1. 2.5hp pull cord
    By Saltshaker in forum Suzuki Outboard Forum
    Last Post: 08-27-2014, 02:08 PM
  2. Pull cord not retracting
    By jimbob25222222 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-29-2013, 01:34 PM
  3. OLD 6hp Pull Cord
    By mikebenghp in forum Johnson Evinrude Outboard Archive
    Last Post: 12-01-2009, 12:39 PM
  4. Pull cord
    By jerry101 in forum Mercury Mariner Outboard Archive
    Last Post: 11-09-2009, 09:57 PM
  5. 98 pull cord
    By red_dwarf in forum Mercury Mariner Outboard Archive
    Last Post: 02-19-2008, 07:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
