Ok this is a long two part question my motor is bogging down on full throttle it will try to plane out then rrr rrr rrr like its hit air bad or something plane out then after hot it want go full throttle and primer bulb will get sucked closed and it's also all new. And u can see air in fuel pump bowl So I rebuilt carb then replaced all lines i ordered a fuel pump rebuild kit but it seemed like it was from 1967 package was fell right open but I replaced anyway still same thing. But I noticed on marine engine diagram two of the same fuel pumps but one with a diaphragm spring one with out and my model number 80753r it shows it if you search for model but then says not available so I cant tell if its spouse to have spring or not! So if someone could tell me if it does or does not have it that would be great or maybe if I have a different problem?
